Re: Help with Governer on B
Posted by gene bender on March 14, 2007 at 01:51:45 from (67.55.226.214):
In Reply to: Help with Governer on B posted by GNB on March 13, 2007 at 17:21:43:
Do yourself a big favor and get the I&T MANUAL fir the tractor it covers how to set the linkage from end to end you dont have the linkage correct or you would not have the symptons you describe.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
