Re: H Flywheel/Starter
Posted by Roger Mills on March 14, 2007 at 11:32:39 from (64.122.113.206):
In Reply to: H Flywheel/Starter posted by IndianaRed on March 13, 2007 at 13:11:49:
I went through that with a MM Z. The new ring gear did not have one side beveled. The starter would sometimes hit the end of the tooth and just clank. Local mechanic changed to a clutch drive on starter and no problems. He said that old style bendix SHOULD have beveled teeth on ring gear and then they only act up when worn badly. Makes some sense but his opinion.
