Re: farmall m turning in wheels
Posted by georgeky on March 15, 2007 at 12:38:18 from (205.188.116.133):
In Reply to: farmall m turning in wheels posted by james braley on March 15, 2007 at 12:16:39:
If you mean slide them in it is a simple chore. I loosen the 4 wedge block bolts jack tractor up just enough to get a iron digger(spud bar) under tire lift up taking a little weight of axle and push on top side of tire. You can also rock back and forth a little walking them up.If you mean turning dish and all be sure not to let it turn over on you, if loaded with fluid you should have help or a loader as they are quite heavy and will have to be completely removed from tractor to turn around. I can do this in a few minutes, but if you have never done it I assume it will take longer. It is not that big a job. This is just how I do it others may have different method.
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
