Farmall Tractors Discussion Board
Re: Farmall MD-super MD
Posted by Ronnie on April 26, 1999 at 04:58:01:
In Reply to: Farmall MD-super MD posted by murray on April 25, 1999 at 20:16:58:
The MD was 3 7/8" from the factory and you can go to 4" pistons. The Super MD was 4" from the factory and you could go to a 4 1/8" piston. Don't know if you could go to the 4 1/8" in your MD that might be where the block won't be the same. If you get the 4 1/8" to fit that would be worth it, maybe you could have a machine shop to bore the block so the big sleeve would work. With the bigger pistons you might have to set the pump up to the Super setting so your not running to lean on fuel.
Post a Followup
: Re: Re: Farmall MD-super MD
