Re: wide fronts for H
Posted by Steven@AZ on March 16, 2007 at 04:54:42 from (24.121.155.253):
In Reply to: wide fronts for H posted by banjo on March 15, 2007 at 20:57:57:
With some minor modifications a wide front from an H thru 560 FARMALL will fit. With a few more modifications you could get a front from a 06 or 56 series as well - the bolt pattern for the main mount casting is the same, different mounts for the bracing to the frame and the steering arm.
I've sold original IH wide fronts for $450 and bought a Schwartz for $300, be patient and don't overpay.
