Re: farmall m turning in wheels
Posted by D Slater on March 16, 2007 at 05:17:07 from (64.12.116.71):
In Reply to: Re: farmall m turning in wheels posted by CNKS on March 15, 2007 at 17:52:03:
Agree with CNKS its best to make sure the rim clamp bolts and nuts are in good shape before turning wheels around. After you have a flat is not the time to find out your clamp bolts are rusted tight if you leave them turned to inside. Jack up one side at a time and if you have a air wrench its easy to take rim off and turn wheel around on same side and finish it before going to other side. Makes it easier getting to wheel clamp bolts with rim out of the way. May be overkill but I always remove wheel clamp bolts and wire brush rust and dirt from threads before going back.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
