Farmall Tractors Discussion Board
Re: Super M RPM Range
Posted by Ronnie on April 26, 1999 at 05:28:08:
In Reply to: Super M RPM Range posted by Wanna be farmer Jeff on April 25, 1999 at 18:32:51:
Jeff get a hand held shaft tack and put it on the PTO shaft and it should turn 585 R.P.M. no load (fast idle). That should have the motor running at 1600 engine R.P.M. Low idle is 625 engine R.P.M. and 230 R.P.M. on the PTO shaft.
Post a Followup
: Re: Re: Super M RPM Range
