Re: W6 still won't charge!!
Posted by chadd on March 17, 2007 at 22:00:18 from (4.188.133.16):
In Reply to: Re: W6 still won't charge!! posted by Janicholson on March 17, 2007 at 15:00:09:
Nope, I had not switched the gauge from when it had originally been positive ground. I just knew enough that when I reversed the polarity of the charging system, the gauge read backwards. Also, a drain or charge of well over 30+ amps would still seem to indicate something is wrong. I can't run the tractor more than 10 seconds or I start seeing the poles of the generator getting hot. The little chrome nuts are already blistered.
