Re: FARMALL H TRANS LEAKS
Posted by Michael Soldan on March 18, 2007 at 05:24:26 from (24.235.41.226):
In Reply to: FARMALL H TRANS LEAKS posted by JFAVOR on March 17, 2007 at 22:36:50:
Nat2 is correct, you do not need to go into the transmission. Its been a while since I did my H but I had to put a pipe wrench on the collar of the drive shaft to turn it off to replace the seal.I don't recall if the pump shaft is the same but it definitely comes off from there for a seal change. Its all done from the belly pump area of the tractor.
