Re: Replacing Farmall M Head Casket
Posted by El Toro on March 18, 2007 at 16:08:41 from (205.188.116.133):
In Reply to: Replacing Farmall M Head Casket posted by on2wheels on March 18, 2007 at 15:49:03:
If these are studs, I wouldn't replace them unless
the threads are worn or the studs are loose in the block. Then the threads in in the block need to be inspected. Some may need heli-coils installed if there's a lot of slop in the stud hole. You need to inspect the nuts too.
If you find a lot of loose studs each hole should
have tap run thru the threads and blown with air. If I found a lot of them loose I think I replace all of them along with new nuts. Hal
