Re: Toolbox for H from 1939 to ??? This style is d
Posted by D Slater on March 18, 2007 at 16:15:29 from (205.188.116.133):
In Reply to: Toolbox for H from 1939 to ??? This style is diffe posted by Scott Rong on March 18, 2007 at 06:02:57:
One you mention is aftermarket as far as I know. Down side on the few I saw was steering shaft wear at place strap went around it or strap worn out. Also it would put a little drag on steering if much weight is in tool box.
