Re: Another dumb question hydralic oil
Posted by old on March 19, 2007 at 07:47:40 from (4.245.5.246):
In Reply to: Another dumb question hydralic oil posted by Gary in Mozarks on March 19, 2007 at 00:04:02:
As the others have said you can let it sit a few days and most of the water will fall to the bottom. Then if you want to hurry things up some stick it in a freezer so it freezes the water in the bottom. Then just pour off the hyd oil. Of course doing that will not get it all but it will get 80-90% of it. I have a friend that has a 450 that has a weak pump and has a loader. After it runs for 30 minutes or so the loader will lift but will not lift a load more then about 200lbs or so. We hooked up a preassure gauge to his system so we know its the pump thats bad since after 30 minutes or so it has all of 500PSI if that much
