Not a problem at all. 95% of the bearings used in the Farmalls are actually standard metric bearings. I replaced 100% of the ones in my '54 SH. I bought some from McMaster Carr and most from a local bearings place here in Milwaukee. For starters: Trans main shaft rear - 6309 (45x100x25) / Trans driving shaft rear - 6308 (40x90x23)/ Trans countershaft rear - 6209 (45x85x19) / Trans countershaft front - 6206 (30x62x16) / Trans driving shaft front - 6207RR (35x72x17 w/ring) / Trans main shaft pilot bearing (358036R91) can be purchased at your IH dealer. / Differential - 6213 (65x120x23) / Bull pinion shafts - 6211 (55x100x21) / Rear axle outer - 6213 (65x120x23 shielded one side), you can buy shielded two sides and pop one shield out / Rear axle inner - 6212 (60x110x22) / Let me know if you want the phone number of my bearing guy, I'm sure he would ship it all to you, his price is the best I've found. He can do all the grease seals too.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
