Re: what to know about 706
Posted by chuck46 on March 19, 2007 at 20:00:39 from (64.136.27.229):
In Reply to: what to know about 706 posted by bob IA on March 19, 2007 at 17:16:06:
Hi, The engine life should be very good, I ran a 315 combine for 35 years, doing 3-4 hundred acres of corn, soybeans and oats-barley every year. That is the 221 engine which is the same with a shorter stroke and runs at 2800, the only work I did on it was change oil, tune ups and a water pump. I have never understood the problems with the TA. I have a 350DU, 350D, 450D, 756, 856, 1468 and have not had a single complaint. The 856 went 13,000 hrs on its factory torque, and I use it a lot. Good Luck, Chuck
