Re: True, but...
Posted by A. Bohemian on March 20, 2007 at 10:20:38 from (207.170.88.187):
In Reply to: Re: True, but... posted by chadd on March 20, 2007 at 09:47:36:
While I respect both your points of view, and I retired from the Six Volt Conversion Wars many years ago, I think you are misunderstanding me.
My electrical system certainly CAN handle the strain of "priming" (my term, not IH's) the fuel system. If the tractor has been run recently, or the battery has been on the charger, I just hop in the seat, yank the starter wire, and go.
The procedure I outlined is for those times when the C has a marginal battery or the state of charge is questionable and I MUST start it, right away.
That, or when I am showing off that it will fire and run on the first pull of the crank with the ignition on.
There is nothing weak or feeble about this system. I maintain it properly.
