Re: My model a is guttless
Posted by Dave BN on March 20, 2007 at 14:43:12 from (64.12.116.71):
In Reply to: My model a is guttless posted by Brett Judd on March 20, 2007 at 11:22:05:
You should be able to start from a dead stop on level ground in 4th gear. This is my simple test for how my tractors are running. You will have to slip the clutch a little, but at full or nearly full throttle you should take right off. If not you have a problem. Does the linkage to the carburetor move as load increases? If so the govenor is probably OK. Maybe you need a tune up or the timing is off. Yes, check fuel flow as stated below also. Let us know. Dave.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
