Re: Plugged filter again, and again, and again, 4
Posted by Janicholson on March 21, 2007 at 10:21:37 from (199.17.6.122):
In Reply to: Plugged filter again, and again, and again, 460U posted by Gary in Mozarks on March 21, 2007 at 10:12:11:
I think that you are seeing exactly that red coating that has been applied to keep oil in a cast Iron case. It does not fail often, but when it does, (for what ever reason, including combinations of additives in the fluid) it is a mess. Were it Mine, I would install a large inline filter housing in the suction line and construct a 120 mesh screen to go in it instead of a filter. Then cleaning it would be moderately easy, and it would have 20 times the screen area of the original. Good Luck. JimN
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
