Re: 1086 international
Posted by chadd on March 21, 2007 at 10:45:38 from (155.92.30.94):
In Reply to: 1086 international posted by mc306ky on March 21, 2007 at 10:14:03:
I would say to check the hydraulic oil filter and screen (right side of tractor, located on the transmission housing right behind the right rear tire). If those are good, either the hand pump (the one under the steering wheel), the piston in the cylinder on the front end, or the MCV pump itself are bad. Yes, the hydraulics, brakes, Torque-Amplifier, and steering system all use the hydraulic fluid from the rear frame, which serves as the reservoir. You check the fluid level with the dipstick that is located in the back of the tractor, right under the fuel tank and above the three point hitch arms.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
