Re: IH 200
Posted by gene bender on March 21, 2007 at 11:07:18 from (67.55.226.214):
In Reply to: Re: IH 200 posted by VAJerry on March 21, 2007 at 08:55:29:
Make sure the mower is set correct that being the front of the blades should be 1 inch lower than the rear. Just point any blade forward and measure the height at the front then the rear. Keep the belts tight so there isnt any belt wobble when running. WOODS says more belts are ruined buy not being tight enough. You have lots of power do it when dry and use 1st gear. Take off the end plates so the mower can discharge material.
