Re: Generator not charging
Posted by Janicholson on March 19, 2009 at 18:06:06 from (66.173.50.177):
In Reply to: Generator not charging posted by techted on March 19, 2009 at 17:50:33:
Here is the simple first test.
With it not running, and a charged battery and all wires connected, Jump between the Bat terminal and Gen terminals on the regulator. This polarizes the generator. It should be done with a piece of solid copper insulated wire 12 ga or 10 ga. (ends bare)
There should be a nice fat spark. Hold for no more than one second.
Start it and run at 1/2 throttle or more. It might be fixed. If not.
With it still running fast as above, jump the F terminal on the generator (smaller post) to a good ground. It will not spark much, but it should charge. If it does, try grounding the frame of the regulator to the chassis and see if that fixes it. If not, it may need a regulator.
Look several posts down the page (maybe 2) and find John T Charging system analysis post He has one fine set of procedures. JimN
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
