Re: 574 overheating
Posted by JayWalt on March 21, 2007 at 19:32:37 from (70.226.9.210):
In Reply to: 574 overheating posted by Grinder on March 21, 2007 at 17:36:24:
kinda odd. Make sure the mower is in good shape, no seized bearings, sharp blades.
I would also do a general cooling system check. Seems running a mower would be more demanding then using hydraulics every now and then to plow or run loader. The mower is a constant demand device, unlike the hydraulics.
What makes you say it overheats? temp gauge goes high or it boils over or what?
Sounds like more of inadequate cooling then anything having to do directly with the pto, its just a matter of the pto loads up the engine more then running a few hydraulic cylinders...
Clean out the radiator with compressed air, make sure the fan works, has the thermostat ever been replaced and so on..
