Re: I H 1486, 3 point not picking up
Posted by IaGary on March 21, 2007 at 20:18:51 from (207.177.17.177):
In Reply to: I H 1486, 3 point not picking up posted by Ron Bailey on March 21, 2007 at 17:53:31:
If its the pin I'm thinking of its not a quick fix.
Is it the pin that holds the lift ram in place to the rock shaft?
This is a small pin and breaks easy if you lift the arms over the height that cylinder is designed to lift them.
Say you back over a pile of dirt with a blade on the 3pt and the pile is high enough to push the 3pt arms up higher than they were meant to go. It will break the 5/16ths pin that holds ram in the socket.
The ram then falls out of the socket when the pin is broke.
Or was he referring to a pin in the lever linkage?
Gary
