Re: farmall H electrical problems
Posted by Janicholson on March 19, 2009 at 18:13:58 from (66.173.50.177):
In Reply to: farmall H electrical problems posted by tgrewing on March 19, 2009 at 17:39:07:
Put a amp meter on the system (if it has an amp meter working in the switch box, use it) Turn on the ignition and watch the amp gauge with it stopped. It should show 2 to 3.5 amps draw. If it is more like 6 or 7 amps, I would use a good hand held amp meter (Multi-Meter set to amps, not Milliamps) as follows. Take off the wire on the side of the distributor. Put one ;ead om the distributor post, and one on the wire end you removed. Turn on the ignition (not started) It should read about 3.5 amps or less. More means the coil is not right. (a super hot coil might do this, or a bad coil (even new)). If it is in spec, I suspect oil or grease getting on the points. JimN
