Re: 1066 Sound
Posted by Owen Aaland on March 22, 2007 at 13:14:26 from (65.165.246.14):
In Reply to: 1066 Sound posted by TSH on March 22, 2007 at 08:16:07:
Use a soap solution around the injector seals to check for bubbles while the engine is running. A bad leak leak may not make any bubbles but will blow the soap solution from around the injector seal.
Valve problems are not that rare on these turbo charged engines, especially exhaust valves. Once the guide gets too much wear, the oil film on the valve stem and guide can no longer seal the exhaust gasses from leaking up the valve stem. Once this happens the guide quickly wears and the valve will no longer seat properly. I have taken engines apart that still ran pretty well but had one or more valve springs that were completely filled with carbon.
If you remove the valve cover you can do a quick check by just trying to move the top of the valve stem. The wear will be side to side on the engine, not front to back. If you have any noticeable play in the stem the guide is worn out. Any carbon deposits inside the valve spring area is a sure indicator of too much wear.
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
