Re: C135 piston sleeve question
Posted by Owen Aaland on March 22, 2007 at 13:24:51 from (65.165.246.14):
In Reply to: Re: C135 piston sleeve question posted by vinnyJimbo on March 22, 2007 at 07:29:33:
The groove under the top lip of the sleeve is a radius cut which serves two purposes.
The groove insures that any imperfections on the top of the sleeve bore do not interfere with the fit of the sleeve.
More importantly the radius cut spreads any stress under the lip across a wider area. A square cut under the lip would concentrate any forces at that point and could cause the sleeve to crack.
This is the same reason that crankshaft journals must keep the radius when being reground. If a sharp step is allowed to remain the shaft will crack or break much easier.
