Re: H generator
Posted by bihl on March 23, 2007 at 10:07:39 from (24.22.192.172):
In Reply to: Re: H generator posted by Roger Mills on March 23, 2007 at 08:46:41:
if tractor has a distributer disco battery with tractor running, if it dies its the gener. if it cont. to run it is the battery. This will only work with a dist. type tractor not a mag setup.
