Re: H generator
Posted by gene bender on March 23, 2007 at 10:28:54 from (67.55.226.214):
In Reply to: H generator posted by ryanfisher on March 23, 2007 at 08:15:19:
Quick and simple test. Ground the field and if it charges on the ammeter the reg is bad. If grounding the field doesent show any charge the gen is bad. Also chech the voltage with engine off and then check again with engine running. If voltage doesent increase when engine is running the gen is at fault.
