Re: H generator
Posted by Bob M on March 23, 2007 at 11:30:29 from (151.190.254.108):
In Reply to: Re: H generator posted by chadd on March 23, 2007 at 11:17:55:
You should experience running a 2 row mounted corn picker, or operating a 2 row bean puller under those 6 volt lights!
Now I agree they throw enough light so someone else in the field will see you/not run you over. But they're marginal for anything else...
Incidentally I always wondered why IHC bothered with the "Dim" setting on the light switch. All I can figure is it was some sort of twisted joke by a disgruntled IHC electrical engineer. (They should have been labelled "Dim" and "Even Dimmer"!)
