Super M coupling fit
Posted by Jim In Shiloh Texas on March 24, 2007 at 12:34:09 from (68.90.129.123):
The driveshaft coupling engages a woodruff keyway in the driveshaft. Is there an intrference fit between the coupling and shaft or is this a slip fit with the key holding the entire torque?
