Re: Removing steering gear on a M
Posted by 460anger on March 24, 2007 at 18:16:26 from (72.251.32.233):
In Reply to: Re: Removing steering gear on a M posted by Gary Puckett on March 24, 2007 at 18:08:46:
Yeap, H is the same. The only thing that holds shaft in is the gear and castle nut, and the weight of the tractor. The shaft coming through the gear is tapered, so usually it doesn't take much to break it loose. Just do like I said and you should have no problem. Can't talk to you any more tonight, I'm going to bed! Good Luck!
