Re: Ajusting and replacing belts.
Posted by Haas on March 24, 2007 at 18:33:06 from (12.65.72.127):
In Reply to: Re: Ajusting and replacing belts. posted by Hugh MacKay on March 24, 2007 at 02:39:16:
Yes, you are correct, if things are rusted up, it may be necessary to hold that nut on the back side. And..it's very important to not round off the hex on the shaft. I had a friend a while back that was trying to replace the generator belt on a cub. He had tried and tried to turn that nut on the back to get the fan belt loose. I took one look at it and asked for the 13/15 open end wrench. 1/4 turn on the hex on the shaft was all it took for the fan to fall down so the belt would come off. He was amazed!!!
