Re: H engine timing
Posted by Tom Windsor on March 25, 2007 at 08:07:28 from (69.40.61.69):
In Reply to: Re: H engine timing posted by georgeky on March 24, 2007 at 21:23:11:
George
Single dot to 2 dots apparently does not work.
My crank gear has a single dot "on" a tooth.
The cam gear has a single dot "between" a tooth and a doble dot "on a tooth".
The distributor gear has a double dot "between" the teeth.
APPARENTLY, TO ME, it seems that single to single and double to double is proper???
TW
