Re: Dim 6V lights
Posted by Gary in Mozarks on March 25, 2007 at 21:07:42 from (66.43.47.102):
In Reply to: Re: Dim 6V lights posted by chadd on March 25, 2007 at 17:33:08:
No matter how you cut it, the lower the voltage a system has the more critical the connections and ground are. also heavier wires) Having worked on a lot of old 6 volt cars, and assuming the generator is working correctly, I would suggest the ground is the culprit. Dialectic grease will help alot on the connections to keep them from coroding.
