Re: The real McCoy SMDTA
Posted by Roger Mills on March 26, 2007 at 06:08:40 from (71.37.118.105):
In Reply to: The real McCoy SMDTA posted by SonnyDay on March 25, 2007 at 16:54:17:
My apologies as well, stick around cause these guys can help getting the 'engine' to run on diesel like it should. There are a lot of things that need to work right to get it to change over from gas to diesel and it really doesn't like to run on gas very long. Find someone local that really does know that engine because it is NOT your ordinary oil burner, AND, get all the service and overhaul books you can find, then read-read-read again. The best thing I can say about the work clothes is that the dirt and oil look honestly earned and it should wash up fine. I'm envious.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
