Re: Battery Charge
Posted by A. Bohemian on March 26, 2007 at 08:20:41 from (207.170.88.27):
In Reply to: Battery Charge posted by Henry C on March 26, 2007 at 07:40:05:
You may need a new battery. Read on... I just hook up the battery charger, red cable to positive and black cable to negative. Which terminal is grounded makes no difference; it is the polarity of the cables and battery terminals that dictate how they are connected. As to how long to leave it charged; ideally you would leave it hooked up until the voltage differential between the charger's circuitry and the battery's terminals was gone and there was zero current flow. Always remember the twelefth of Novem...wait, that's Guy Fawkes' Day. I'll try again. Always remember, I=E/R (Ohm's Law). In this case, I represents current flow, E is the voltage differential, and R is the combined resistance of the cables and connections. I think the battery's internal resistance also plays a role, but I can't positively recall at this time. So, if E=0, I must equal zero in a fully charged battery. If your charger has no built-in meter, you can connect a VOM ("AGAIN with the VOM! This 'Bohemian' guy and his VOMs...") as an ammeter and monitor the state of charge untill current flow drops to zero. However, this is the ideal situation. In fact, I find the battery perfectly satisfactorily charge when the current flow has dropped to %20 or less of the maximum current the unit can supply (NOT the initial current in any given charging application). In other words, with my 6 volt 6 amp charger, I consider the battery ready to go when the current flow reaches about 1.2 amps. I note you are usinig a trickle charger. I am not familiar with these but believe 2 amps is a typical maximum charge rate. It will probably take SEVERAL DAYS to see the charge rate drop to .4 amps, but I will defer to anyone with more experience on that particular matter. Finally, in my experience, batteries that were seemingly fine four or five months ago but that are mysteriously dead have a high failure rate. Some fail to take a charge; most will fail to hold one. Check for voltage with a VOM ("AGAIN!"). You should have two or three volts. Less than that and the prognosis is grim. If you have absolutely zero volts, the battery may have a dead cell and not take a charge. A flickering meter means the battery has developed internal "noise," but I've only seen this once with an automotive/tractor battery. At your convenience, please post back and let us know what you end up doing.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
