To Cedric re temp gauges
Posted by Roger Mills on March 26, 2007 at 12:14:43 from (64.122.113.206):
I found that the temp gauges are made by Rochester and are series 2110/2210 with a standard temp range from 100 to 250 degrees F. (vapor pressure range for methylene chloride) I do not know yet whether the one with the arrow for pre '47 A tractors has the same scale as the one for post '46 but that one also reads from 100 to 250 but has the color bands on the face. Rochester says they "could" re calibrate the gauge but it would be custom work and $$?? The folks at Rochester should call me back with that info as well as the temp range on the other gauge.
