Re: 230/water coming out of exhaust/ HELP
Posted by Janicholson on March 26, 2007 at 17:58:19 from (66.173.50.173):
In Reply to: 230/water coming out of exhaust/ HELP posted by Ben.So.Tex. on March 26, 2007 at 17:07:26:
I would put a radiator pressure tester on the radiator, then pump it to the Pounds specified on the cap (usually around 6). Then pull the spark plugs and let it sit for 2 hours, or until the pressure drops to 1/2 of initial #. Then With the coil spark wire grounded, crank the engine while watching the plug holes. Antifreeze will come out of one most likely. You will then know where to look for problems when taking it apart. Cracked heads, leaking head gasket are the most likely. Good luck JimN
