Re: Battery Charge
Posted by dave guest on March 26, 2007 at 18:09:49 from (4.229.123.134):
In Reply to: Battery Charge posted by Henry C on March 26, 2007 at 07:40:05:
If you are lucky enough to have the amp hour rating of the battery, like 75 amp hours or so and your charger charges 5 amps, it should charge fully in 15 hours. If charger is 7.5 amps then time is reduced to 10 hours. Just a nominal rule of thumb, may vary a lot.
