Re: Different crank seal question
Posted by CSR on March 27, 2007 at 03:41:23 from (192.249.47.8):
In Reply to: Different crank seal question posted by Roger Mills on March 26, 2007 at 15:30:23:
You have to remove the timing cover because the seal goes in from the rear. I just started all the bolts, figured I'd finish running them in after the pulley was installed and concentric with the crank seal, but I couldn't shift the cover around before I installed so the pulley, so I just tightened the cover. My pulley ID measured about .002 smaller than the crank. I gave it a light flapper wheel, then heated the pulley to 300F for 3 hours. At 1.25 in diameter (going from memory), a change in steel temperature of 230F (300F-70F) will change the diameter .0018 which reduced the interference fit from .002 Tight to .0002 Tight. A light tap with a block of wood and a hammer and it slid right on. I then started cooling the pulley immediately by wrapping a water soaked rag around it (next to the seal) till the rag smoked, then I'd resoak and do it again. I lubed the crank up good with oil before I started and made sure I put some camshaft assy lube on the seal also. Most silicone rubber products are advertised as good to 500F so I felt 300F was OK, plus the wet rag pulled the heat from the pulley rather than have it heat soak the seal.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
