Re: gas in breather oil cup?
Posted by JayWalt on March 27, 2007 at 05:59:15 from (69.214.159.61):
In Reply to: gas in breather oil cup? posted by nspec on March 26, 2007 at 19:36:57:
cant recall, as my compression tester is in the shop, but they do tell you how to determine if its valves, worn rings or a head gasket. If I remember right its like this.
If you have the same low reading in 2 cylinders beside each other, its indicative of a breached head gasket.
If you run the cylinders dry and find one with low compression, then u put a bit of oil in through the spark plug hole and it raises the compression, its indicative of eaither a cracked ring, stuck ring, or worn rings/sleeves.
If adding oil has no effectm then it is a valve problem.
I think this is what the manual says, please feel free to correct me if I'm wrong.
