Re: Stall out
Posted by Janicholson on March 27, 2007 at 11:40:49 from (199.17.6.122):
In Reply to: Stall out posted by Christie on March 27, 2007 at 09:21:55:
Disconnect the fuel line at the carb with good line wrenches so as not to abuse the hex. Place the end of the line in a coffe can and open the valve. If a steady stream bigger than a coffe stir stick comes out for long enough to almost fill the can, the issue is in the carb body. If it only trickels out, there are four places to work on.
The screen at the fitting may be plugged.
The line may be rusted/plugged.
The sediment bowl and screen above it may be plugged.
The fitting in the tank above the bowl may be plugged. Compressed air, Carb cleaner, time and effort will get it cleared up. JimN
