Re: H carbureator
Posted by kfox on March 27, 2007 at 18:28:08 from (63.18.237.14):
In Reply to: H carbureator posted by G Campbell on March 27, 2007 at 18:20:48:
If you don't tighten the packing nut around the bottom carb adjustment, it will leak. I had one H that I tightened the packing nut until I was blue in the face (almost) and it finally quit leaking. The leak looks like its coming out of the drain hole in the bottom of the carb, but its actually the packing nut. ken
