Re: loader ???
Posted by Owen Aaland on March 28, 2007 at 07:24:34 from (65.174.247.66):
In Reply to: loader ??? posted by PJBROWN on March 28, 2007 at 05:23:41:
It looks a lot like the 2050 loader that is on my
I-2444. Mine has two separate levers for the
valves instead of the joystick and does not
have the brackets on the upper sides of the
loader frame. Mine has a cross member
bolted across the front where yours looks like
it has been extended.
My tractor is a 1968 model so I would assume
that the loader is probably a bit older than one
that came on a 86 Hydro.
There is a stainless steel plate riveted on my
frame that looks like it may have been an ID or
serial number plate but it is completely clean.
If that is what it is for the numbers must have
been printed on rather than stamped.
