Re: Now what do I do? Super C
Posted by glennster on March 28, 2007 at 09:13:20 from (68.78.143.252):
In Reply to: Now what do I do? Super C posted by cole on March 28, 2007 at 08:27:06:
pull the distributor cap off and crank the motor over see if the rotor is spinning. if so good. check the cap for moisture, wipe it out good, spray some wd 40 inside the cap and then wire it out to get rid of any water. pull a spark plug, lay it against the motor so the side is grounded, with the plug wire hooked up, crank the motor and see if it sparks. could be bad wires or bad plugs.
