Re: Now what do I do? Super C
Posted by old on March 28, 2007 at 09:14:07 from (4.244.218.34):
In Reply to: Now what do I do? Super C posted by cole on March 28, 2007 at 08:27:06:
Cap and or rotor could be bad, or it could also be the insulator going into the distubutor and if its bad you will not have spark. With the switch on and the points closed if you open them do you have spark at the points. If you do then probably the cap and rotor are bad. If not then probably the insulator
