Re: super A block
Posted by Hugh MacKay on March 28, 2007 at 12:08:19 from (209.226.247.107):
In Reply to: super A block posted by mar B on March 28, 2007 at 09:03:19:
mar: The block from all Super C and Super A after serial numbers 310000 are the same, and the block part number is 354898 R1. Super A before 310000, A, B and C all share the same block, I don't have that part number.
Farmalls 100 and 200 have block part number 354898 R3. Farmall 130 is 366204 R1 and 140 is 367825 R2. I cant tell you if 230 and 240 are same as 130 and 140 respectively.
Bear in mind everyone of these engines will bolt up to any of the tractors listed, they just require different sleeve and piston kits to match the engine.
