Re: 1256 Steering
Posted by Owen Aaland on March 28, 2007 at 14:09:15 from (65.165.246.14):
In Reply to: 1256 Steering posted by Brian in AR on March 28, 2007 at 10:08:36:
Is this a problem that occured after you made a change, such as installing wider tires? Wider wheels and tires can greatly increase the force needed to steer the wheels. The axle is designed so that the axis of the steering spindle, if extended to the ground, would come out in the center of the tire tread. This allows the tire to pivot on the ground when steering. Moving the tire out, away from the axis, forces the tire to move in an arc rather than pivioting. If the tires are not the problem, it is possible that the steering pressure relief valve has failed or the o-ring on the valve has blown out. Any leak or other problems in the MCV should cause some change in the brake operation while steering or cause the oil pressure light to come on. Problems with the steering hand pump, the control valve, or the steering cylinder should still be noticable with the tractor moving.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
