Re: Etching Primered and ready for the Red
Posted by CNKS on March 28, 2007 at 17:42:11 from (204.249.178.32):
In Reply to: Re: Etching Primered and ready for the Red posted by Tom Windsor on March 28, 2007 at 15:24:03:
I doubt if you will have problems, particularly with the dilute spray can stuff, but I don't think you are supposed to use etch primer on cast because of the acidity, it can get in the pores in cast and lift the topcoat. Best to use epoxy primer. Etch primer is primarily for body shops that use it on new sheet metal so that they don't have to sand. However, I used to use phosphoric acid products on cast without problems, I don't anymore. Something to consider, I am by no means sure of this. But, epoxy will do as good as etch and has no potential problems that I am aware of.
