Farmall Tractors Discussion Board
Re: Re: water in oil on m-farmall
Posted by Walter on April 28, 1999 at 06:15:40:
In Reply to: Re: water in oil on m-farmall posted by RKS on April 28, 1999 at 04:35:53:
If you determine that the head gasket is blown don't forget to check the head to see if it is warped, use straight edge and a feeler guage to check top of block also. You may have to get the head resurfaced.
Post a Followup
: Re: Re: Re: water in oil on m-farmall
