Farmall Tractors Discussion Board
Re: h belly pumps
Posted by john d. on April 28, 1999 at 06:49:19:
In Reply to: h belly pumps posted by Chuck M on April 28, 1999 at 05:26:11:
Might fit; most of it should be the same. Does the Super H have the same size clutch as the H? If so, you're likely in free. I ran into trouble trying to put an M pump in a Super M because the Super had a larger clutch and the M pump was not recessed on top for enough clearance. I'm guessing this won't be a problem on the H line, but I don't know.
Post a Followup
: Re: Re: h belly pumps
